clinem03
- Sep 9, 2017
- 400
I just removed, restored and reinstalled the OE oil pan in my 76 with stock 302. There appears to be oil leaking out from the front two corners and under the timing chain cover (new one, with a new timing chain 500 miles ago) where the pan connects/lines up. I have a single piece fel-pro gasket in there. I cleaned everything up and installed the gasket and pan when everything was dry.
Should I have used RTV on those front corners and where it means the TC cover?
