Pretty much yes. Since once customizing takes place, no two Broncos seem alike. But even before that, no two owners want the same thing in the same place.
Making a "kit" kind of a useless gesture except with certain things. Especially when mimicking stock, a kit might make sense. But braided stainless lines? Again, maybe for fully stock replacement routing. But not once custom modifications start.
Things like:
Gas tank? Which one? Or which two?
Fuel switching? Which type?
Fuel pump brand and type? What location?
Carburetor? Which one?
Throttle body injection? Which one?
Port fuel injection? Which one?
Just those few questions probably result in at least 20 possible answers. So which combination and where do you like the hose to run would pretty much make a kit useless.
I should not lay a blanket answer like that though, because if someone came up with a reasonable pre-cut setup that was laid out really well and somehow managed to work with multiple components, it could probably be done.
But it's still going not going to please everyone.
VERY CLEAN setup you've got there bronkenn! I know we've seen it before, but it never gets old.
Being a '66 puts you at an already lonely disadvantage Copper. Holes will be in different locations and none of them made for a tidy engine compartment. The Painless harness (and all the others except a stock replacement) will be patterned after the '71 and later style. So you're going to be customizing from the get-go. Which might actually be an advantage!
Probably going to fill up or cover some existing holes and make some new ones.
I see the PO already upgraded and moved a few things. Can you get a better pic of your alternator? Looks like a 3G unit, but I see what appears to be a voltage regulator on the passenger wheel well. If a 3G they probably just never got around to removing the old one. Or maybe you installed the later alternator yourself?
With the new harness you can move all sorts of things to your satisfaction. You can put the starter relay wherever you want it to keep things clean (but leave it accessible or you'll probably live to regret it!), remove the old regulator, and even move the fuse holder for the charge circuit to a more out of the way place.
Lots of cool stuff you can do when starting from scratch.
have fun!
