There is a vacuum port in the runners to both cylinder #4 and cylinder #8. These are OK to be used for manifold vacuum, but should not be used for the PCV valve. What that would do is put all the vapor from the crankcase into one cylinder. The PCV valve should be connected at the base of the carb. If there is no specific PCV connection on the carb, use a carb spacer. That way the vapor is distributed evenly to all cylinders.
