Oleguy is right. You don't necessarily need to replace a good coil. And how you connect the Ignitor depends entirely on what type of coil and how much voltage is delivered to it.
Josh changed his for other reasons, but not because it had to be 12v to be compatible with the Ignitor.
The bottom line is that it's the Ignitor that must have the full 12v no matter what coil is used, to operate reliably.
What that means is that if you are running an 8v coil (like the stock one) you cannot take the power for the Ignitor off of the coil's positive side. Instead, you have to find an alternate source of power that's on with the key in RUN only.
The reason this gets confusing is that the instructions from Pertronix show the most convenient way to connect an Ignitor module's Red wire is to run it to the positive side of the coil.
It appears in the diagram that this is acceptable at any time, but what they actually say in the text, and show in the diagram, but is not always clear until you look more closely at it, is that you need to hook the Ignitor to the battery side of any resistors. This gets the full 12v to the Ignitor module, while the coil still gets the reduced voltage.
So, for the Centech Mazeing mentioned, connecting it to the coil + side is perfect if no ballast resistor is used.
If a stock, or stock-type coil is retained, the ballast resistor is still used, but the Red wire is connected to the side closest to the battery.
Even Pertronix sells Flamethrowers with resistance values that make them compatible with stock resistor wires, so if you're going to be eliminating the resistor you have to choose the correct one of their 12v compatible coils. It will have more internal resistance built right into the coil itself.
I've heard here that it doesn't effect performance, but I've read in ignition books (I think?) that using a 12v coil with the full available voltage (without a resistor) is better for delivering a longer more reliable high-powered spark to the plugs.
Guess I'll have to go back and re-read the book. It was actually a fairly interesting, good reading book put out by Jacobs Electronics years ago.
Check it out if you ever have the chance.
