BruiserOutdoors
- Aug 22, 2013
- 741
My bronco came with 2 shocks at each corner. I have elected to remove the additional aftermarket shock brackets on the front (stroppe style), in front of the coil spring pocket,
My question is whether or not to remove the added front shock mount brackets on the frame on the rear of the bronco? Will I regret this? Should I utilize these mounts? My main desire for removing them is that they are sort of "bent" looking, though this just might be the way they were. And if I run a single rear shock on the bronco, an unused mount will look odd.
I plan to run just a single Bilstein shock at each corner for now with potential to upgrade the rear setup in the future. (408w 6r80w atlas 2 37s)
Let me know what you would do.
