jesus888
So we have a freshly rebuilt 302. Petronix Flamethrower 2 coil. New distributor, cap and rotor, plugs, etc...
Issue:
Cannot rotate distributor to what we think is the correct spot because the TFI module hits the Coil!!
Description:
Currently, after setting the motor at Top Dead Center and the rotor pointing to the #1 plug, then rotating to 10 degrees, the distributor can be in 1 of 2 places.
I am going to describe the placement related to a clock.
From a previous attempt at starting the motor (removing Petronix from bracket and setting it a little out of the way), we found that rotating the distributor to around the 4 o'clock position got the truck REALLY close to starting.
SO with the coil back on its bracket, when rotating the distributor backwards from the 6 o'clock postion OR forwards from the 3 o'clock position causes the TFI module to hit the Coil before we get where we need to be!
Please help
Issue:
Description:
Please help
