Nothing Special
- Nov 25, 2016
- 805
After installing the Wild Horses oil pan kit (#8066) my engine is really slow to build oil pressure when first started. I'm used to it taking maybe 5 seconds to build pressure on the first start-up after an oil change, and for the gauge to start climbing pretty much immediately after starting all other times. But now it's taking maybe 15 - 20 seconds for the gauge to start moving, and then another 5-10 seconds before it gets up to the ~40 psi that it typically idles at (assuming my gauge is accurate...). Once it finally builds I'm getting the same oil pressure that I got before the pan change, but it's just taking a lot longer than I'm comfortable with for the pressure to build.
I used the new oil pickup tube that came with the kit. After removing the old pickup from the oil pump I couldn't get the remains of the old gasket off the pump, so I took the pump off to clean the gasket surfaces better. With clean surfaces and a new gasket I put it together with no gasket sealer.
I didn't have a new gasket for between the oil pump and the block, but that gasket came off clean so I just put that back together without doing anything else. If that was leaking I could see not getting full oil pressure, but I don't really see how a leak at the pump output could cause it to be slow to build pressure.
I know it says that this kit can't be used with high volume oil pumps. I honestly don't know what I have for an oil pump. I bought this rebuilt 302 from a local engine shop. I figured if I had a high volume pump that it would be pretty easy to tell if it wasn't fitting. But the oil pickup tube seemed to match up perfectly, the support tab also lined up perfectly and the pan went on fine, without seeming to hit the pick up tube before it was tight against the block.
Does anyone have any suggestions on what might be going on here?
