Pax84
Newbie
- May 16, 2020
- 26
I’ve recently installed a new (rebuilt) gauge cluster and speedo cable in my bronco due to my old cluster failing. I recently went to move the truck and letting off the clutch in first gear to an idle speed, my speedo needle went crazy and even started to get hung up on certain speeds.(30,50,70, all while going slow in first gear) I then pulled the cable out of the t case and used a drill to test the cluster, with the plastic drive gear on I got the same symptoms and even had the clip fly off the drive gear. When I took the drive gear off, my cluster seemed to work smooth and fine no bouncing no hang ups and went consistent with the speed of the drill. It seems obvious but is this a failing drive gear? Or am I not assembling it correctly, I pushed it all the way down and clip it in, while in this position I would get the bad symptoms on my cluster. When I clip it further up on it shoots off.
