RottenBanana
Newbie
- Jul 6, 2020
- 39
Hey guys,
So I dropped my ('73) truck off to have some front end work done at the shop. I gave him a brand new collapsible shaft and appropriate U-Joints from Duff's. There's some slop in the steering that I'd like to get rid of, and I wanted to ditch the rag joint because it hits my inner fender slightly due to a 3" body lift.
Well, the shop called... And it's bad news. He said there is for sure some play in the lower U-Joint, and in the steering column itself. The biggest issue was that the rag joint is welded onto the shaft, so he's unable to simply swap the shaft out as intended.
After searching around, I've seen that others have had the same problem. What are my options here?
- buying an entirely new column is fine, but costly.
- How difficult is rebuilding the column myself? I don't think it would be bad, and most parts can be bought from the vendors
- Should I cut of the rag joint, trim the shaft to a DD and weld a U-Joint on?
Any insight or experience appreciated
