- Jun 26, 2023
- 43
My ‘66 has a pretty severe front steering wobble when it gets to about 30mph and the road is bumpy. I can “float” through it with a little more speed, but it really isn’t very safe right now and has been like that since I acquired it.
I just finished working on all the brakes, replaced shocks and springs all around, and new tires. Trying to keep everything pretty much stock.
Underneath…the tie rods and pitman arm all seem good and tight.
I think the issue is the original manual steering gear box. I can spin the steering shaft by hand in either direction with little to no resistance.
I’m thinking I will just replace it, but they also sell a power steering conversion kit that sounds tempting. I know that I would have to replace the single crank pulley with a double but not sure if my motor has needed holes for mounting the pump.
Anybody have any suggestions on which direction I should go? I don’t mind the manual steering because it is just going to be a weekend cruiser but now would be the time to upgrade to power steering.
Here are some pics of the underside steering components and the side of the engine where the pump would need to be installed.
