I installed the doors, fenders, hood, and grill. The hood gaps were terrible and the fenders did not have a straight line going down the hood line. At about the 6" remaining on that fender line, they bowed in toward the hood to a near 0 gap although the gap everywhere else was at least 1/4" to 5/16". Further, the hood was bent and cracked. I attempted for several hours to bend it back in shape and weld up cracks, but in the end, it was not salvageable, at least not by me. It also had several dents. So I bit the bullet and bought a new hood. Hoping the aftermarket hood is usable although I will likely need to modify to some degree to make it right.
The fenders and the grill took some work to get them to line up with near 0 gaps but eventually that worked out. However, the rear gap at the door is giving me fits. Shims, washers, a small bend here and there and they are close, but until I get my hood, I wont know for sure. I might be in the market for fenders...ugh. The lines are very important to me. I spent many hours lining up the doors perfectly before welding in the rockers. Needed to shim the rear body mounts to bring the top rear of the door gap close enough (moved it in about 1/4") and put hinges in press to get a 1/16" door movement forward. However, that was still not a perfect gap so I am using a cutoff wheel to slit the upper quarter panel right at the gap and moving it over 1/16" or so and welding it back up. That turned out perfect. The gaps along the back are parallel to quarters at 3/16" top to bottom. The gaps along the bottom rockers are slightly more at 1/4" or maybe 5/16"., but straight and parallel all the way front to back. The gaps at the fender are close at 3/16" to 1/4" but until I get the hood, wont be able to dial them in completely.
So. all that to say that before I take it off the frame again, I plan on getting all the gaps near perfect including the tail gate and the window frame. I'll put the top on tomorrow to dial in the window frame to door window gaps.
Finally any suggestions on what I should try to get in terms of hood to fender gaps?
