I have a set of Superior 31 spline axle shafts going into a new 9" rear axle. Since this is all new, can I run tapered roller bearings, instead of the stock Bronco roller bearings? I read a few threads here thru search, and it looks like there may be 2 different OD measurements that will dictate if you can run roller bearings only or tapered bearings. I think the #'s were 1.531"? & 1.562"?
Can someone who's BTDT give a definite answer if an aftermarket 31 spline axle can use a tapered bearing instead of a roller bearing?
Thanks in advance.
Thanks in advance.
