LOTO_DLG
Hi, last fall I picking up a 74 Bronco in fairly decent shape. I drove it around just a bit, around 5 miles, and it seemed to be solid. In my spare time I'm been cleaning up the engine bay, put headers on it, MSD, ...the usual stuff. My plan is to put several shakedown miles on it before I work on cosmetics. Yesterday I went to drive it for the first time in months and can't get it to move. When I shift from Park to Drive it does nothing. I haven't touched the transmission and it worked fine when I parked it. I did however mess with the Transfer Case shifter so now I wonder if it's out of gear. I THINK I have it in 2wd high but I'm not sure. I can feel it shift into 4wd low and high but even then it doesn't move.
Is there a trick it this? Should I be pushing down, (or up) in the shifter. Of if you think I'm off base with the transfer case could it be something else?
Any advice would be greatly appreciated.
Thanks,
~David
Thanks,
~David
