hammer
- Nov 13, 2006
- 1,359
Hey guys,
The story - Went to the local pick n pull. Spent 4 hrs pulling parts only to get to the cashier and realize i left my wallet at home. Its 4 pm. They close at 5. I'm 25 mins each way. Challenge accepted. I bomb home, bomb back, I'm really givn'r. Couple miles from getting back to the pick n pull truck suddenly loses power (im in 5th gear probably doing 80 mph), starts popping out the exhaust. I pull over. Bronco is idling fine. Nothing noticeably catastrophic. I hop back in. Rev it up. Starts sputtering and popping at higher rpm. So I continue on, riding the shoulder, low rpm in 3rd gear. Get back to the puck n pull at 5, turn the bronco off, pay for my stuff and get back in the truck. Wont start.
Ended up troubleshooting for an hour and a half before getting it towed home.
Ford efi. rjm harness. I have spark. I have fuel. I can't test fuel pressure or run codes until sunday. I run a lp pump/accumulator/hp pump. I have fuel to the fuel rail and both pumps seem to be working fine. I have spark but swapped another spare tfi that I have just to try. Didn't do anything, still have spark. Checked vacuum lines. Everything looks fine.
