RustBeltRefugee
Sorry, I didn't literally mean that the input shaft was lubing the 'case, but that stuff that spins with it does. The high speed gear on the front output shaft turns with the input shaft as you note, but that also means that it stays stopped with the input shaft as well. And with the trans in park the input shaft (and therefore the high speed gear) can't turn.
However that link is helpful. The front output sliding gear will turn if the front hubs were locked, so it would make sense that it would lube the 'case well enough. Again, for me personally the risk of burning something up while flat-towing isn't worth the little bit of labor savings to not drop the rear driveshaft. But at least there is some basis for saying leaving the hubs locked will work.
Drag from where? The unlocked front hubs? There's way more drag in the front axle, front differential, front driveshaft and transfer case then there is in the hubs. None of that will turn if the hubs are unlocked.
Sorry, the Dana 44 hubs look like they disengage enough to not cause much if any drag. Just me but if I was getting under the truck to disconnect the rear then I would probably just go ahead and disconnect both driveshafts. Because once I start worrying about things I usually start worrying too much. Otherwise I would just lock the front hubs and put the transfer case in neutral and leave the driveshaft connected. I would have to do a search but I think I have read about members successfully using the latter method.
Doing a search here before flat towing would be a good idea before flat towing. Flat towing seems to inherently have risks but it has it's merits. There is a lot of information regarding flat towing aside from transfer case and transmissions concerns on this site.
