eRandall38
Newbie
- Nov 3, 2018
- 16
Have one damaged wheel (not pictured), attached is a photo of one of the other same wheels.
I took the wheel to a tire shop yesterday to be measured, they said it was a 15x6.5... but "that measurement must of been off and I should get a 15x7", does that sound correct?
In trying to find 15x7 I have tried a few local places as well as online refinished wheel sites. No one seems to be comfortable in sending me the correct wheel. I have found some that look the same, but they are concerned about "the offset" and do not recommend buying.
I have told them 15x7 (still not sure if tire place is correct on that), 5x5.5, and also that the OEM hubcaps I have need to be able to pop onto the wheel. The below picture does not have the hubcap on, but it normally does.
I am not worried about the wheel look or if it matches, since the hubcap will cover, I just want it to be right. Everything I have found makes it sound like this is 1980s style Ford Bronco wheel? The front disc (this is for a front wheel) conversion is a 1977.
https://ibb.co/jgnrkwL
