pcf_mark
- Jun 11, 2010
- 3,645
Search simply does not digest "hydroboost" and "brakes" well and you get crazy threads.
Hydroboost install (my second) with canned ham OEM pump with T in the return line with the straight path going from booster to pump. After several stops the brakes begin to drag. After enough stops (10 or so) they drag enough they slow you down. If you park and let it sit engine off for 10 minutes problem goes away for another 5-10 stops.
I thought if it was a too long push rod it would do it from the first time I used them. Do I need a brake return spring to make sure the pedal fully returns?
Thanks guys.
Thanks guys.
