Inner door post brackets
75MIKE
NE Washington
Does anyone know of any of the vendors sell the hinge plate brackets separately?
Some that look better than these? Thanks
Skinnyr1
I pulled and replaced the outer panel to replace just like you did. Ended up custom making the hinge brackets out of simple angle iron.
Yours appear to be in decent shape though, to either fix and reuse or to make a template from to remake.
langester
MASTER OF MADNESS
I had the same issue on mine, I made my own and welded them in, basically a couple simple pieces of sheet metal bent up.
75MIKE
NE Washington
Thank you fella's. yes, Looks like that is the way to go. Couldn't handle the thought of destroying $200 worth of door posts to get the brackets.
