I put the pistons, crank, cam and rollers back in my block. She's all pretty. This is a 2000 explorer 302.
I'm about to order the oil pump, oil pan, oil dip stick tube, water pump, timing set, and valve covers.
Just wondering if everything should be stock for the explorer or if there say a better oil pan for the bronco. I'm assuming all the explorer stuff is fine, but since I have to order new that it makes sense to ask. My oil pan and valve covers are too rusted on the outside to bother with them.
Some one posted a part number for the oil filter bung that I need. Explorer had some hooky extension piece. On looking farther into it there seems to be a hole where some other sfb's have a check valve, Do I need one?
Last question, I'm looking at the rock auto 3 piece timing set. The crank gear has three keyways. +-4degree or 0degree stock. I was planning on buying it since its the cheapest but best looking kit there. Can I just put it -4 degree for more torque in the low end?? And that's it? no ecu reprograming or anything. I feel like theres more to it with all the other sensors and crap. My Ecu is currently already reprogrammed by EFIGuy.
