1/2" spacer needed between WP pulley & pump?
OsideDave
Looks like I need a 1/2" spacer between water pump pulley and pump or fan will hit alternator and power steering. I finally got all pulleys lined up on the 351W and now this. Looks like I will need another new harmonic balancer or deeper 3 bolt 2 groove pulley. Any ideas. These pulleys and harmonic balancers are driving me crazy.
sprinksbeme
Kingman, AZ
My stock WP had a 1/4" spacer between the pump and pulley, a 1/2" spacer won't leave much shaft left for the pulley to ride on.
What kind of fan are you using. Flex fans blades are huge and they are known to eat radiators
Flexlite 1018 or 1017 are low profile fans might give you the clearance you need. 2818 and 2817 are the reverse rotation models.
SpareParts
I have a spacer in between mine to get my pulleys to line up also, I think mine is around 1/4 to 3/8". I made mine out of a scrap piece of alum. that I had laying around. Like stated before, if it's thicker than that you will not have any of the center stud left for the fan mount.
David
oleguy74
calif city ca
pulleys
every thing is from my 302.swapted it out in 1979 to my 351w.the three grove crank pulley is there beacause it came with a/c.
av bronco
Palmdale CA
I was told because I have a aftermarket balancer I needed to run a spacer,it took a little patience to line everything up. I also have a 351 block.
O
OsideDave
Not sure why I didn't think of that %) , I just put the spacer between the pulley and fan and its fine. My old setup had the spacer on the inside of the pulley - gotta think out of the box.
Thanks for the help. Saved me from searching for a fix.
