#1 not firing efi really need to solve
Green-Machine
well i just got done putting EFI on and it ran great but for some reason my number 1 just stoped firing im getting fuel i know because i can see it dripping from the header and im getting spark i can see it arc over.
i have a new distributer and coil
Steve83
Running the engine with open headers is risky, even if you DON'T have fuel dripping out. I'd put some kind of pipe on there before running it again. Are you certain it's gas dripping? It should evaporate inside the cylinder coming thru the injector and never condense.
JohnJohn
Richmond
My vote is for a stuck open injector. It happened to me twice. Guess that is what I get for buying rebuild injectors from eBay.
If you disconnect the wire from the injector on the suspect cylinder and there is no sound/RPM change then it is most likely a stuck open injector. I have also been told that a stuck open injector can’t be fixed but a stuck closed one can be. Don’t know why but I replaced mine.
I had white smoke rolling out of one exhaust pipe with unspent fuel.
Steve83
I've unstuck closed injectors on my engine & this one simply by grounding each bank of injectors to heat them up until the goo melts enough for them to open. Mine has been running fine now for ~14 years.
I've never seen a Ford injector stuck open.
NYLES
yeap im gonna vote on that one myself so far 4 outa 8 of mine are bad
G
Green-Machine
the headers are on i can see it dripping through the gasket
G
Green-Machine
i switched injectors around and it still does the samething im going to check the compression see if its good.
G
Green-Machine
How long did it run great?
did it run great cold and hot?
it was running good for a couple of days and then i went to start it this morning and i could smell gas dripping and i touched the header and it was cold on that cylinder even once it warmed up
badmuttstang
redneck grease monkey
could be stuck injector or loss of compression you should ohm out the injector if it high or low check the rest should be around the same if that one is way off then bingo you have a bad injector stock injectors should have around 11-18 ohms and please unhook the wires before checking don't know how many people I have seen try and ohm out something still hooked up.
badmuttstang
sound like a dead cylinder start checking for bent valves possible rocker slipped off or rings are bad just my guess
Is this just an EFI to old engine swap? Or did you replace the cam and other valvetrain components too? If so, is it a roller or flat-tappet cam?
G
Green-Machine
Not sure i bought this motor from some guy he had someone rebuild it but it is an old style engine but i have no idea what he had done to it He cant find the papers.
Ratch
Check your injector harness, If you have a short to ground in the line it will hold the injector open.
