bknbronco
So what did you end up doing? First off how big of suspension lift? Did you do tie rod over or under? Stock or drop pitman arm? How big is the drop on that trac bar drop bracket?
After looking at them pics looks like TRO with a drop pitman arm? Looks like the trac bar needs a riser bracket on the axle?
I ask because im ready to do the same steering swap to mine. I have a 5.5" lift. And as you can see im in desperate need of some reworking to get the angle more parallel to the ground%). As you see in the pics im starting from all stock parts. Id like to go chevy TRE and do it TRO. Going TRO as well as having the chevy style drag link TRE, (which moves the connection point way out toward the pass tire) will make the drag link much more flat with the ground...as shown in second pic. Also wondering if i should go with drop pitman arm? I have read alot of threads that say no need for drop pitman with TRO? Then after all that ill fab up a trac bar riser bracket to fix that.
Maybe i should start my own thread but thought if i knew your lift size and other details id have a great starting point!
