11 pack or 9 pack?
The stock height versions are usually not 11 leaves because they don't need that many. Probably not as desirable either if you can get away with 10 of the same thickness leaves to arrive at the desired height with perhaps an even softer ride.
In our case at least, they're 10-leaf packs. No reason to make them with 11 if not needed.
It's not the same as the discussion here regarding Matt wanting to know the difference in 9 or 11 leaves for a given height (in this case 3.5") might make.
He's curious what the difference might be due to the thicker individual leaves, in a spring pack utilizing more arch to achieve the same height.
I don't think anyone has offered different versions of the stock-height model other than literally "stock" with 5 or 6 leaves, vs 9, or 10.
Not sure I worded that the right way, but you're not seeing 11-leaf stock height packs because it takes fewer leaves for stock than it does for lifted.
matt w
matt w
If I was happy with a product that i had for 10 years, I don't care if the leafs had 8 or 20 leafs I wouldn't even think about buying another vendor's product personally.
It is interesting because the MFG I bought them from 10 years ago does not offer the same thing I got from them. Also there is one MFG that offered 2 different spring packs for the same 3.5 lift. I wanted to see that since I had extreme sag after only 2-3?years of use, & they were 11 pack, I was wondering if the 9 pack they offer was going to perform "better or worse" than the 10!year old 11 pack.
Here is the link to the 2 different leaf packs offered by one vendor. Why does this vendor offer 2 11 pack kits when some of the others only offer 1?
This is why I'm hitting this awesome group of experiences bronco owners their opinions and input! http://www.dufftuff.com/category_s/126.htm
bronconut73
For the additional weight of a hard top and bumpers or the much lighter Roadster style.
matt w
matt w
To all I decided to order from here. They are custom
Making them for me to 500lbs over stock springs. That takes into consideration steel plate bumpers, spare tools , ice chests, 5 gals of water, oversize spare tire, winch, extra jacks., towing a small trailer with camping gear, 3 gas tanks! yes 3!!, etc., etc. shoot I even tote around snow chains in the bed in the winter. I blew through a set of 3.5 inch springs in about 2 years and I added a “add-a-leaf”. After about 10 years, 2 leaves finally snapped at the add-a-leaf section on the drivers side. This custom set will cost about 100.00 or so more than the “off the shelf offers” out there. I will post updates as to ride quality, performance when towing and loaded down and finally Offroad flex on the trail. http://www.alcanspring.com/ ALL THE BEST!
