Well there are two different 12si front frames, and 14 different CS130 frames. But with that said, you most likely have the standard 12si front frame, and there is an exact match CS130 front frame. If you are going to the wreckers for one you will have to wait untill Tuesday for me to get into theshop and figure out what it came off of.
The wiring is a bit different as well. (Though either can be made one wire). In the back of the plug there is a P L I/F S . You can use a switched wire on the I/F terminal to turn the alternator on and off. If you want a light circuit you have to use an LED bulb, and run it to the L.
We make these units (my most popular) mostly as one wire. Just hook a battery up and go. For reference 120amps is $120, 160amps is $160. Canadian, which doesnt make much difference right now. They are bigger bearing, HD recitifer units, that charge hard at idle.
