I would try richining it up some. If you have a advanceing timing light I would check to see what your total advance is. I would not go over 45 total advance. If your total advance is to high and it has adjustable vacum advance on it you can bring it down there. pull off off the vacum on the distributor and inside the hole there should be a allen head you can turn in there if it is adjustable.
