68 170 manual, vacuum questions
Beagleye
I have 1968 bronco, 3 speed on the column, 170ci. I don't understand the vacuum system. I'm not sure it's correct. Is there a place where I can find a complete diagram?
A couple of details.
Three ports on the manifold, one on the carburator.
The carburator port goes to the end of the distributor side cylinder.
Two of the manifold ports go to the little blue vacuum valve thingy (which has 3 ports)
The blue thingy/valve third port that goes to the side port on the distributor side cylinder
The third manifold port goes to the wipers via the fuel pump. Amazingly this is the least confusing part of the system.
I have pics but I don't know how to upload them.
Uploading pictures takes contributor status. Small yearly fee.
The carburator to distributor is probably correct. Ported advance.
The rest of the vacuum lines and ports, I would just unplug them and cap them (excpt the distributor port, want that one to breath as the ported vacuum works).
The blue thingy, probably in the water jacket? Thermal valve, changes something with the vacuum at some temp.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
From 68 Ford shop manual:
bmbm
Looks like you got the help you need. If you have other questions about your 170 you can visit fordsix.com. They are very helpful also.
Didn’t know either. Never saw any reference to it in the aftermarket books, or the few factory books I looked at. But then again, I probably wasn’t looking for it either and may have glossed over it.
bmbm
It may be unimportant but I recalled reading about some 1968 Ford 170/200 in Bronco having two systems being thermactor and imco with some differences between the two. Thermactor may have been standard for vehicles sold in some states:
Yes, mostly CA of course. Here, a '66 Bronco (at least with the V8) had a thermactor (air pump) where some other subsequent years did not.
A '76 would have had one, but not sure about '77. A '72 did not come with one here, but not sure about '73's? None of the '73 models I saw had a pump.
But all the ones from '68 to '73 that I messed with, did have this little vacuum doohicky/thingy for the vacuum advance.
My '71 (from out of state) had one.
I disconnected it pretty quickly (as did my friends with '72's) because we hated how the idle hung high after letting off the gas.
Shifting gears it was nothing more than a minor annoyance occasionally. But letting off the gas to coast or slow down, really ticked us off since it would hang for a few seconds and not let you slow down as you were expecting.
Sounds like some of it could have been adjusted out.
