1966 Front Center Hose?
iwlbcnu
I can not find a factory rubber front center brake hose. Ordered a 67-75, but it is a different style. Any ideas?
U13FL735
Your wanting the brake hose right off the master cylinder I'm thinking? Nick at Northeast Classic Ford has reproduced it for the '66.
WILDHORSES
USA
https://www.wildhorses4x4.com/product/Front_Brake_Hose_Center/Bronco_Brake_Hoses
Something different about the one we offer for a '66?
Haven't done one myself, but the '66 is listed right there at the top.
Those are for stock height trucks in either rubber or stainless.
Here's the stainless one for a lifted Bronco:
https://www.wildhorses4x4.com/product/Front_steel_braided_Brake_Hose_for_Lift/Bronco_Brake_Hoses
The 66 is the freak hose that goes with the jelly jar master cylinder. You have one reservoir feeding the whole brake system. The brake fluid flows through the 66 front hose WH #3177 to both the front and rear brakes. Only do this for a true restore otherwise upgrade the master for better brakes and safety.
Jim
Tonyduc
Just replaced mine. Went to NAPA with the old one. They found the rubber hose with two female ends part # 36599, then two 8" metal line with male threads on each end part # 8135610. Bend to fit with the proper tool. Total parts cost about $38.
Tony
