1966 Restoration "Where do I start"!?
Dixie Killers
I've had my brother's 1966 sitting in my barn for many years, it hasn't run since 2000. My brother has been gone for 5 years and my now 14yr old daughter asked a couple of years ago if her uncle Keith's old truck could be her fist car. That was 2 years ago and I had "plenty of time" to get it ready for my baby. Wel....put off put off put off and bow I have 2 years to get it ready for a new driver. I starting pulling old seats carpet and basically stripping the inside last Saturday and quickly figured out.....I need a schedule and a budget!
Which I've made, at least I started....
My time line is 21 months and my budget is 50k firm. I'm not a mechanic or body man but I'm fairly handy with both. Pulled motor & Trans yesterday - motor is shot so I plan to buy a summit 302 crate long block. Floors, 2 fenders hood and dr door need replacing everything else including chassis and frame are pretty good.
Where do I REALLY start??? Frame off?
Motor? Chassis? What comes FIRST!!?? Thanks all Bronco enthusiasts and all comments and help GREATLY APRECIATED!!
Sorry for lengthy post...just wanted to lay it all out there.
Scoop
Bronco Old Fart
Cuchara, CO
To get this done in your timeframe, I would recommend NOT doing a frame off. Everything can be done to make it safe and very presentable by dong a frame on restoration. For your daughter's safety be sure to include adding a rollbar/front cage, 3-point seat belts, power steering and power disk brakes. I also recommend NOT installing a rear seat until your daughter has plenty of driving experience under her belt. This will prevent her from piling a lot of friends into the Broncowhile she's still a newbie driver. I would do the body work first, chase next and then do the engine and drive train installation. What tranny are you planning? Auto or manual?
I did the same for my son for his first car.
Good Luck!
D
Dixie Killers
Good Luck!
Automatic. The original transmission works but I'm guessing it won't work with new 302 or auto shift.
I'd planned on the disc breaks and pwr steering but never thought about roll bars and back seat so thanks for that!
I'll try and post some pics along the way.
I hope your son loved it!!
I'm letting my daughter turn some wrenches and help out with as much as she can.
Thank for the advice!
1strodeo
Squirrel Watcher
Wisconsin
Hi there, what part of the country are you in/where has the Bronco spent the majority of its life? How closely have you inspected the body for the extent of the visible rust? As Scoop mentioned, that is where I would start for sure! Visible rust usually leads to more rust, of course, so give the tub a thorough inspection to see how much work you're looking at. The body seems to be the biggest hurdle to most restorations I've seen. Best of luck!
D
Dixie Killers
The wet part! 7 generations of cows oranges and humidity. Man I've gone over this thing with lights and cheaters(reading glasses). Got real cozy underneath removing drives exhaust tranny and engine even put a wire wheel to several suspect areas.
I don't want to fool myself so I've really dug in. Floors front and back are the worst so I'm going to start with new front and back and go up from there.
This will be an in town truck and won't see much if any hwy travel.
My buddy that's helping is a speed guy and keeps pushing for more power stronger trans ect. I just want safe and enough speed to get out of the way if she needs to. I just want the safety and reliability to be there and to look pretty for my high school daughter.
I appreciate the help...so much great advice and I'm very appreciative!
Thank you sir!
gnpenning
Bronco Slave
Should be a great project for you to share.
Please resist the urge to add much power wise. Short narrow wheel base with high center of gravity in the hands of a new driver is a recipe for disaster. Think of it as a safety item.
Be sure and update with pictures as you proceed.
Edit: you updated while I was slllowww typing. Your daughters safety over rides everything else.
