I'm reviving this 7 month old thread just to update it, and post what I learned just in case someone else stumbles on in in the future.
The 1967 Thermactor system on the Bronco is unique, but it does share some parts with other Ford Intermediate cars. The Pump, Diverter, outlet hoses, diverter bracket, vacuum lines, check valves, alternator tensioner bracket, and heads are all C6OE parts. The Smog pulley, upper and lower pulley, alternator mounting bracket, smog pump tensioner, smog pump inlet filter canister, and smog inlet hose are 66-67 Bronco V8, CA emissions ONLY. They are C6TE parts...and were all revised in 68.
The pulley system uses the 289 style 3 bolt damper, (C5AE) and double sheave pulleys on the water pump and crankshaft. One v-belt routes around the crank, water pump, and single alternator pulley. The other v-belt routes around the crank, water pump, and smog pump. That configuration uses the catalog belts listed in the MPC.
The surge tank is also Bronco specific, and carries a C7TE part number for 67. I don't know what's different about the 1966...but Ford revised the part number for 67.
The smog pump inlet filter is Bronco...but you could probably make one out of a 67 T-bird body and a 67 Mustang 6 cylinder top.
Thanks to Justin (thegreatjustino) and Doug for the pics.
