1969 U15 Sport Build
R
rguest3
I picked up the Half Cab from a member here from Ft. Lauderdale. Thanks Sam.
The Half Cab Top and Swing Out Tire Carrier are already dropped off at the body shop. Top will be Wimbledon White and the Tire Carrier will be body color. I am hoping this one will be done in a couple weeks, tops.
I'm eager to bring it back and finish the rest of it. Parts have been waiting for awhile.
pipeline010
Looking forward to seeing this combo.
Originally I hated the half-cab look but I'm starting to warm up to it.
R
rguest3
The Half Cab can look a little short, especially if it also has a lift. It will look longer with the tire carrier on the back.
R
rguest3
I finally have the Bronco back front the body Shop and in my shop to complete the build. Now I have some work to do.
Here is what it looks like as of today.
I really like the Half Cab look but it does seem a little short. It will look a little longer to the eye with the spare Tire Installed on the back.
LUBr LuvR
Very classy look - the argent grill and red in the emblems really pop on that color. Coming along nicely, congrats on the progress.
R
rguest3
Thank you.
I had second thoughts about the color at first, but I really like it.
Funny, my favorite part, which I do to most of my Broncos, is the Red Oxide Epoxy on the underside. The Black frame, Stainless Brake and Fuel Lines and Silver Trans and Drive Shafts really POP!
sprdv1
REBEL
looks really good man...
R
rguest3
Thanks.
I have all the parts to complete the build. I'm just hoping I can stay on it and get it done in a seasonable time frame.
R
rguest3
I got the F-Series serpentine system mocked up today. Ford replacement High Flow Water pump, 180' Thermostat, 1/2" Fan Spacer, 17" Rigid Fan, Toms Aluminum 5.0L conversion radiator. i'll also install the Original Bronco Fan Shroud with minor trimming to clear the tensioner.
There is about an inch clearance from fan to radiator. The PS pulley will need to be pressed in farther to align with other pulleys. I will also have to measure for a correct Crank Pulley Spacer.
I have never had an issue with this set-up and no overheating even here in Hot, Humid Florida. This fan moves a TON of air.
sprdv1
REBEL
Thanks.
Always the hardest part... Everything else wants to interfere..
Good luck sir..
I feel your pain
R
rguest3
I got these Dodge wheels in last week. They are 17x7". I was curious about Fitment so I mocked them up on my Yellow 77 to see how well they clear the knuckles. Plenty of room even for wheel weights.
But, these wheels are for the 69 Half Cab Sport with 255/80R17 (33/10.50/17) Toyo ATIIs. The center bore had to be enlarged (3 1/2") to fit over the Front Hubs of the Bronco. I also have the wheels drilled and tapped for the later Bronco Center Caps pictured.
With a 3" Lift and Uncut fenders these should be a nice fit. I painted them the Same Argent/Silver as the Front Grill of the truck to match.
R
rguest3
I got the Dodge 17" wheels and 255/80R17 Toyos mounted today. I am very happy with this combination. Keeps in Touch with the Old School Look. The wheels are painted the same color as the Grill Center.
Looks fantastic. How tall do the tires actually measure out at on the vehicle?
Oh, and it looks like you've already done your first version of the "chalk test" with the tires. Might want to check the air pressure, since I see dirt only on the center ribs of the front and the back in the picture.
Could just be skewed by not much drive time on them, but that's what it looks like to me.
Howard2x4x4
Truly a thing 'o' beauty! The color combos really knock it out of the park!
sprdv1
REBEL
Very nice sir...
R
rguest3
Thanks all.
Hey Paul, any marks on the tires is from me rolling them around the shop. I'll start with 30psi and go from there. Advertised at 33/10 but I'll take a height measurement today for you.
R
rguest3
Using a tape measure, the front tires mounted on the Bronco are 32.5" Tall.
R
rguest3
I decided to go ahead and add A/C to this truck. Much easier now than adding later.
The Original Heater Box has been pulled and a 4-Port Bulk-Head Connector has been installed in the center of the Firewall.
