1970 Bronco Belt Replacement help
skatanic13
i'm new to mechanical stuff, so please forgive my ignorance. i get a high-pitched whine/squeal under load. i want to replace the belt and clean the pulleys to see if that fixes it, but i've run into two problems. first, i dont know how to remove the belt. i tried looking up diagrams or instructions online, but couldnt find anything. i cant seem to locate a belt tensioner to remove it. the second problem could be a bit more serious. while looking at diagrams, it occured to me that there should be 2 belts present, while i only have one. the bronco had after-market power steering added a few years ago, and theres one belt running everything (alternator, waterpump, power steering, crankshaft). is that a huge problem? i know there are dual grooved crankshft pulleys available, would it be best to install one of those? i've included a few photos. thanks for the help.
https://imgur.com/a/AlWCc
okie4570
NW OK
Welcome! Loosen the adjustment bolt on the alternator, slip the belt off the pullies and over the fan, reverse procedure to install the new one. Your current belt could just be loose as well.
JAFO
Beaverdam
Two belts are better, but one works. One belt it sort of takes more tension to hold everything tight. The belt could be slipping, or it could be something else. Make a white mark on the belt and the Alternator pulley. Start the engine, rev it some (or drive around until you hear the squeal). Now stop and then turn the motor over by hand (or bump it with the key) until you get to the white mark on the belt to be at the alternator pulley. Does it line up with the alternator mark you made? If yes, pretty certain the belt did not slip.
You have a clutch fan? Fan will have a clutch in the center instead of being a solid center bolted to the water pump shaft. That might could squeal if going bad.
Power steering pump could be squealing maybe?
As mentioned, I'd try just putting more tension on the existing belt if the white mark test points to belt slippage.
In your first pick, that bolt upper left at the alternator... the alternator rotates on that bolt and below the other bolt on the alternator will be the adjuster bolt. Loosen both bolts. The top bolt just slightly loose. The bottom bolt a little more loose. Now use a pry bar to put more tension on the belt by slipping the alternator so the pulley causes tension. You want to have just a slight bit of belt deflection when you press your thumb down on the belt on one of the longer free sections of the belt. Now tighten the adjuster bolt and the top pivot bolt.
If no more adjustment left and you cannot get the belt tight, then the belt is too long and you need to get one 1/2" to 1" shorter. Probably 1/2" shorter will work. A good parts supplier can get the number off your old belt and give you one shorter if required.
Crush
Greenbottom, WV
In your pics it appears as though tour power steering pump and pully is at an angle compared to the rest of the pullies. If this is so then you need to straighten up that pump and then tighten the belts and it should not squeel. I had one like that and it sqeeled incsssantly($2 word for the day:) )
Rustytruck
Your set-up doesnt wrap the water pump pulley much. It just kind of dances across it. Good news the pump should last forever. Bad news is any loss of belt tension and you wont have much energy driving the water pump. You need to add a custom idler roller between the fan pulley and the power steering pump. That's why most V belt systems us multi belts.
jckkys
It appears that some PO added a Saginaw power steering pump without all the parts. Ford power steering systems had 2 groove pulleys on the crank and water pump. The second groove is in front of the single groove. That's why the steering pump pulley doesn't line up with the crank or water pump pulleys. The rear belt that only turns the alternator and water pump has a large engagement area at the water pump. The front belt turns the water pump and power steering. The 2 groove pulleys can be found for less than 40 bucks ea. shipped. Squeals are usually from the alternator working at maximum amperage. The power steering pump usually doesn't squeal unless the wheel is turned to the limit.
Hate to say it, but you have a hack install. New belt isn't going to fix this. Whoever did the power steering conversion got creative to make everything work on a single belt. Not the good creative way either.
The belt gets traction on the pulley by the amount of contact it has with the pulley. What you have is very little contact on the water pump. Under load (of high RPM and load of the waterpump and fan) the belt simply doesn't have the traction and slips. V-belt accessory drives connect two or three pulleys together. The 4 pulleys all on one V-belt that you have is too much.
The bad part, no simple fix. You only have the single groove crank pulley. The correct 2-groove crank pulley is hard to come by. Once you have a 2-groove crank pulley you need to offset one of the accessories (alternator or powersteering) and run that off a second dedicated belt.
blubuckaroo
Grease Monkey
Ridgefield WA
I wouldn't say the PO was an idiot. The fact that the guy was able to get all the pulleys line up is amazing.
The problem is the combined load on the belt is too much.
The problem isn't that uncommon.
Vintage Air sells a system that overloads the belts as well. And they should be the experts.%)
Pa PITT
Stephenville TEXAS
..I'm going to Muddy the water on this one..
.. I have a different Bronco. That I'm trying to get to stop squealing the belt on the P/S pump.
... So If you go to a wrecking yard & Find a 3 GROOVE water pump pulley look at it closely ... I've found 3 pulleys .. But one of the pulleys I need to use is deeper than the back 2 grooves.
... So while your in the fixing process Look closely.
jckkys
The correct pulleys are easily available. Here's the pump pulley;http://www.ebay.com/itm/Steel-Ford-...ash=item3f4e0c3471:g:4XUAAOSw5VZXA9wb&vxp=mtr. And here's the crank pulley;ww.ebay.com/itm/Steel-Ford-Mustang-289-Crankshaft-Lower-Pulley-65-66-Double-Groove-Painted-Black-/380734302481?hash=item58a5886911:g:CGwAAOxy2FZSS5I0&vxp=mtr. You can find cheesy chrome plated ones too. The 3 groove pulleys came on small blocks with Thermactor, Ford's air injection.
