- Mar 21, 2024
- 262
Hi all,
After clean up found the culprit of my oil leak (well, one of them), front corners and rear of the intake manifold, typical spots. I am going to tackle this weekend. I am going to using the Felpro Gasket Kit as well as Permatex Ultra Black.
Is upgrading to the ARP bolts worth it? I am definitely replacing, just not sure if I should head over to my local hardware store instead. If so, what material for the bolt should I use? I am keeping my stock manifold. Going to put it in a harbor freight path to get it clean, and then respray it with some Ford Corporate Blue.
Thank you
Thank you
