67RT
- Jan 17, 2014
- 1,308
Hi Friends,
After getting a bogus turn signal switch with poor soldering (horn wire at spring broke when I picked it up to install after fishing it through column). Even though the vendor sent me a new one, I think I want to leave it as is and run my horn off of either a toggle or the washer pump switch. The problem is my washer pump is long gone. Not sure which wires are correct. There are a few wires hanging out by the driver wheel well. Specifically, two black wires each with a 90° elbow rubber female connector. If these are the ones my switch must be broken as I get no continuity across them when depressing the switch and no voltage when on acc or run when depressed.
If someone has a pic of the stock wires I would be greatly appreciative. Where do they come thru the firewall?
Thanks, Pete
Thanks, Pete
