On the connector I took the picture of these are the wires on it. Yellow-yellow with black stripe -2 red with black stripes-blue-blue with yellow stripe -2 green with white stripes-2 white with blue stripes-green. 11 wires in a 8 pin connector. On the steering column there is a GM style 8 pin connector. white-green-yellow-purple-brown-blue-gray and black. I just don't want to screw up and start cutting and splicing wires. I appreciate everyone's advice and knowledge on helping me accomplish this.
PLEASE don't cut and splice wires!!!
It is easy enough to make an elegant pigtail that plugs into your factory harness and also plugs into that GM flat multi-pin connector. Someday, if anyone has to restore your harness, they will thank you.
Also remember that the GM column is NOT pin compatible to that connector, and you will have to install a horn relay. The horn on your Ford has two giant wires running thru it. One is battery hot, and goes to the horn brush plate. The horn switch connects it to the other giant wire that energizes the horn. The GM column is a single contact brush plate that goes to ground. Until you re-wire the other end of the horn wires...you can't connect it to the GM horn.
The turn signals are functionally identical. LF, LR, RF, RR, flasher power, and Brake power. (6 wires) plus 2 for the horn.
It's only 8 circuits. Two of the doubled up wires are for the dash signals. They get paired with the front turn lights. It's just a convenient place to connect them.
The decoder matrix was nicely published by "Tom's Off Road 4x4 not Bronco Parts but still selling Parts for Bronco's but had to change the name for copyright, even though Jeff's Graveyard didn't..." attached below.
