I had the same problem on my '74 when I first got it - none of the instrument cluster bulbs worked.
Because I was doing a restore anyway, I ended up taking the entire cluster out, giving it a thorough cleaning, replaced all the bulbs and installed a new headlight switch. When I put it all back together - all the lights worked properly. I believe my issue was a combination of bulbs burned out and the headlight switch was shot internally.
What I did: took the vent box completely out of the driver's side to get good access to the rear of the instrument cluster - I also took a few photos through the vent opening & from the floor board brake pedal area and drew up a diagram so I got all the wiring hooked back up correctly.
Just FYI - the headlight switch has a spring loaded pin that has to be depressed in order to pull the knob/shaft assembly out of the switch, then you simply remove the bezel nut and the switch comes out.
Good luck,
DJs74
