1971 Bronco Sport budget build
ShortBus
August 29th I started building my wifes 71' Bronco Sport. We have owned it since 1997. We bought it in California City, CA (desert), so there is no rust to speak of on the vehicle. For the last three years we have had a great time wheel'in our 05' H2, but it is now out of warrantee and we are looking forward returning it in December. Our goal is to add all of the things that made the H2 comfortable, to the Bronco. Power steering and Brakes, A/C, suspension, and Lockers. We decided to start by freshening up the motor.
ShortBus
ShortBus
Bug Invasion
Wasps were my first challenge. I had to sneak out early in the morning on a calm day to do some exterminating. 2 foggers did the trick.
ShortBus
ShortBus
Cleaned it up for teardown!
knocked off a lot of dirt from the last tour at the bottoms early this year. I also cut the fender flairs a bit to better fit the BFG ATs.
ShortBus
ShortBus
Some under carriage shots
From under the rig!
ShortBus
ShortBus
Parts Pile
This is the pile of parts to start with.... Got these from Harry, of Harry's Hot Rods in Grand Prairie, TX. Great guys down there and fair prices compared to internet deals.
ShortBus
ShortBus
Tear Down
While removing the top end parts from the motor, I noticed a lot of oil and grime. After pulling a seriously fowled plug, the decision was easy to rebuild the motor instead of just bolting the new parts on.. Radiator is bad also. Ordered a new one from Tom's Bronco Parts. The "Coolinator" Heavy Duty , I can't wait to test it out.
ShortBus
ShortBus
Out comes the motor!
Pulled the motor. I had a little trouble with the clutch linkage holding up the drivers side of the motor on the transmission. Once it was disconnected, the motor came out with ease.
ShortBus
ShortBus
Off to the Rebuilder!
I dropped off the Motor at Blaine's Motor Supply in Dallas. They quoted $700 for a long block. The place was clean and the people are nice. I tore down the block to the basics. They are going to install my new cam and timing chain/gears. I just backed the truck up to the bay and they pulled it out with a hoist. Quoted 3 days to do the job. They are going through the whole motor; new bearings, pistons, valve springs, rocker arms, push rods, and they are going to rework the heads by doing a full valve job. They spin the rebuilt motor for 30 minutes to ensure compression and oil flow. So far so good!
ShortBus
ShortBus
The motor is back!
The motor is back for $700 as quoted.;D
Baja71
I'd paint it, as purdy as the rest of it is. What dipstick kit did you use?
ShortBus
ShortBus
There is a kit? I bought a tube bender and stuck it back in the hole. When I took it apart, the last owner had surrounded the opening with shoe goo or something silicone. I was planning on doing the same thing.
ShortBus
ShortBus
Bronco deep in the mud
No Locker, tired motor, angry wife. Priceless moments in the Bronco! ;D
ShortBus
ShortBus
would have expected the H-2 in that shot?
Been there a few times, but the 37" MT's & rear locker help keep it from getting stuck. The old Bronco was running on 7 cylinders and has no traction control devices whatsoever. That will all change soon. I am putting the new (to me) C4 Tranny, that I got from broncpilot, in this weekend. ;D
ShortBus
ShortBus
Some shots of the empty Engine bay
Looks pretty empty when you get it all out.
ShortBus
ShortBus
Took out the carpet kit too....
The floor boards look pretty clean. no rust to speak of. Thank God!;D Plenty of leftover sand from Pismo Beach and Dumont Dunes. I miss the Dunes!
