1972 Rust Repair
Was this helpful?
  • Yes!
    Votes: 5 100.0%
  • No.
    Votes: 0 0.0%
  • Total voters
    5
Bay0726
Bay0726
Woodstock GA
Just making sure everything lines up before welding, and checking gaps with the drivers side to make sure they all lok about the same.
Bay0726
Bay0726
Woodstock GA
Rust proofing the inner rocker. Seam sealed everything. A feeling of accomplishment!:cool:
RIbronco
Costa Mesa, CA
Awesome job!
This is exactly what mine needs for rust repair as well. I'll be using the same method of making patch panels instead of buying complete new pieces.
Thanks for the motivation.
Bay0726
Bay0726
Woodstock GA
Awesome job!
I'm glad to hear it. thats what I was looking for when I started the thread. Glad you could use it! If you need anything just shoot me a line.
Bernie
Bay0726
Bay0726
Woodstock GA
Some Tips
It's important to only cut one section of metal and repair one piece at a time as to not affect the rigidity of the body structure, always keep the doors on, and re-check for proper alignment after each cut and before each weld. If you see any sagging use a jack and a block of wood to try to find out where or what is causing it. I had a slight problem with the pass side and thought it was from the floor support, but it actually was coming from the door hinge post. You can brace it back into position before welding. Once you weld it's too late to go back so be careful take your time and make sure everything lines up before you weld.
Rockers, The aftermarket rockers fit good, you will have to cut a little notch of metal off the top of both sides to get them to fit into place about 1/8th to ¼ inch. They will also fit low below the doors, see the pictures where I was using a floor jack to get them to fit into place. Use your door bottom as a reference to where they should be. Again remember to take your time and make them fit perfect before you start welding, I think I wore out my door hinges by fitting them, closing the door , opening the door and fitting them some more… you get the point. If you start to get frustrated take a break and start over again tomorrow. Don’t be afraid to bang on things a little, you can always go over it with a little body filler later. I’d rather have a small dent then rockers that sit a couple inches lower than they should. If you plan on replacing the upper rocker then you will need to brace you body by welding angle iron or a pipe to bridge the door opening. Also remember to protect the metal on the inside of the rockers before installing them; they are not galvanized as the ones from the factory were. I used rust proof primer and rubber undercoating on mine.
Bay0726
Bay0726
Woodstock GA
My Avatar
To all you who are wondering, I've been asked this a few times... Here is a picture of my Avatar. It's Tasha my 10 year old Boxer taking a bubble bath. She is always trying to lick the soap, hence her tongue is out! lol Thanks for asking guys, :cool:
RG801
Oklahoma City
Lol. I'm not sure I would have ever figured it out. Funny pic.
Bay0726
Bay0726
Woodstock GA
You guys are too funny. lol!
The last of my rust issues! Drivers floor
Bay0726
Bay0726
Woodstock GA
I think it was actually more work to make the patch and weld it in then it would have been to just replace the whole floor. Note to self for next time!
aaron6920
Dorchester, IA
This is the first thread I have seen that makes me want to repair some rust and give my bulldog a bubble bath :)
Nice work coming along nicely!
Bay0726
Bay0726
Woodstock GA
Thanks Aaron, I will be starting on a new project soon and posting a link to it here.
Good luck with your Bronco!
Bernie
Gunracer
Buford, GA
Hey Bernie,
Hope you got the top back to Woodstock in one piece. It was nice meeting you. Keep up the good work!
Roger
Bay0726
Bay0726
Woodstock GA
Hey Roger, Thanks! Made it in one piece! Any thoughts on paint for your Bronco? It will look great if you take it back to the original Grabber Orange...
