1974 Restoration Project
BattleBorn
BattleBorn
Las Vegas, NV
Probably should have mentioned this in the beginning. The bolt broke off when I removed the center.
Is there a fix for this?
BattleBorn
BattleBorn
Las Vegas, NV
Well today I noticed this gouging in the right axel end. It's not where the bearing seats but the lock ring I think. There's no damage to either the old bearing or lock ring, is this gonna be an issue, is it fixable? Im thinking the axel retainer was loose at some point, not sure.
BattleBorn
BattleBorn
Las Vegas, NV
Late post,
Here is a pic of the 3rd member finished, with lockers!
I have a ton of parts to install next. I received a belated Christmas present to myself from WH!!!
Very excited ��
Looks good did you red loctite the ring gear bolts? If not some new bolts come with loctite on them if you got new ones. If you reused the old ones you need loctite on them. Better safe than sorry.
74 Bronco Billy
Kit came with new bolts and red Loctite
Media blasting will allow the parts to really take paint well or PC. HF has a cheap cabinet that you can modify to use well for all the little parts you will be doing. Good luck
Sent from my iPad using Tapatalk
