1975 air cleaner / pre heater hose / exhaust shield pics?
magstar67
Missouri
Does anyone have any pics of the heat shield (I assume) that attaches to the exhaust manifold for the heat riser tube coming from the air cleaner to attach to? It’s missing on my ‘75, I’ve searched on here and can’t find any pics or discussion but may be because I’m calling it the wrong thing. I come from the Mustang world and that’s what they were called there
Better yet, anyone have one they would part with? Thanks
904Bronco
San Martin, CA
Heat stove is what I have called it... Draws heated air by the exhaust manifold up to the Carb during warm up
EPB72
Pleasant Hill, CA
Thermostatic Air Cleaner TAC,,system ,TAC heatstove,,, term used by CARB ,, Heatriser EFE {early fuel evaporation } is the exhaust valve at manifold that forces hot exhaust flow under intake manifold for warm up ..,,,, But no help on parts
With the new terms, you might be able to pull up images of it online. I’ve seen them before.
It was changed however, between 72 and 73 if I remember.
Slightly different shape tube, and, if I’m not mistaken, slightly different diameter.
LUBr LuvR
This is as close as I have in existing photos on my ‘76. Can possibly take more later tonight of the actual shield/stove pipe if no one chimes in before then.
LUBr LuvR
Here’s a few more. Not an easy area to get into for clear pics, and this one is smog equipped - so more in the way than usual.
LUBr LuvR
Here’s a few from a ‘73. Taken from firewall working forward gives a better idea of what the part looks like. Last one is more from above than the first three
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
