1975 BRONCO HOOD JAMMED
FordBronco1975
I closed my hood to my 75 bronco too hard and now the safety latch hand lever is stuck below the lip of the grill. So that piece where you put your hand to pop that safety lever is below the grill and stuck in the lip I have fiddled with it some but worried about ruining paint or bending the grill.
Anyone have any ideas on how to handle??
Brush Hog
NorCal
Haven’t looked at mine but is there some way to get a socket on an extension through the grill and unbolt the latch to take latch off?
EPB72
Pleasant Hill, CA
bolts are from the top,, Try going from under neath an push up on release handle wood broom handle are something alike to reduce potential paint damage and have helper use a hook to pull back through grill ,,,
just peeked at mine ,,, so you can release the hood then it pops up a little but the secondary release handle hits the grill top lip,, the grill is ridged there soyou may have to try loosening the bolts for that release handle looks like you could get box end [12 point} comination wrench in there ,
F
FordBronco1975
Thats what i am going to try today is unbolt it, am worried that screw looks stripped already on other side of bolt so may have issues with that but I dont think there is any other way to get it loose without bending the top where it is wedged. i appreciate, will let yall know how it goes. Ya normal latch works so hood pops up a inch or two then cant fully release it
SLOWnEASY
San Diego, Ca.
Just looked at mine too. If the hood won't pop at all you should still be able to slip a 1/2 inch open end wrench between the grill and the hood and loosen the two bolts. The safety handle is adjustable front to back so you probably only need a 1/2 turn on each bolt to be able to slide the safety back.
Madgyver
Bronco Madman
slip 550 cord around bottom catch a pull it out. it should be enough to pop latch free for grill grip. once out, trim lift tab or grill so it doesn't happen again.
Chiclassics
ya tough it out...dont worry about paint, cord is best bet. You can always get touchup paint to redo any scratches. These vehicles are built to be rugged we baby'em too much , i bet they dont like it.
F
FordBronco1975
I got it, couldnt fit a racthet in there to loosen it. just pryed it with a screw driver it bent the lip a little but then got towel and hammered it back flat so it wouldnt happen again no damage to the grill or paint!
Thanks for yalls help!
