Hotrodjohn
- Feb 12, 2016
- 264
Hes talking about the duraspark module for ignition. They had different color wire tabs coming out of them on different years and applications. 1975 was a green one on Bronco. A 66 had points, not electronic duraspark ignition if its original. Also, I had a coil that would act up and cause running problems even though it checked out good on an ohm meter. So if yours has points and coil you may want to try another coil. It could be a fuel issue as well with what your describing.
