351W block has a larger diameter head bolt, than a 289/302 block.
If using 351 heads on 289/302 you need some type of washer under head bolt.
If using 289/302 heads on 351W block, you need to open the holes up in the heads.
Also make sure water passages in head, gasket, & block line up with each other.
