1976 front end axle
SteveL
Huge chevy guy
Hawthorne ca
Disc usually start about $700 and go up depending on condition and what gears, differential and axles are in it. You could put 3k in a front end real easy.
Looks like a 400 diff. Lot of cleaning work ahead of you!
But a great start. New brake lines, probably new calipers just out of caution, service/check the bearings and you'd be good to go.
If the linkage is intact and not bent, you "can" keep it, but your geometry will not be perfect without some tweaking. Is your Bronco lifted? Bigger tires? If so then you probably don't want that Y-linkage anyway.
If they've got a '76/'77 pitman arm too, you could get that from them at the same time so you have the most options. As long as it doesn't cost extra.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
For as caked up as that is and the rotted off bump stop, I'd pull the cover off before buying to make sure it's not a rusted out mess in there.
sprdv1
REBEL
definitely....
blubuckaroo
Grease Monkey
Ridgefield WA
So, with these '76/'77 axles showing up so often, what's happening to the Broncos they came from? Broncos seldom get scrapped out for any reason anymore.
Maybe '76/'77s may be less desirable in some areas because of emission laws?
Geniusloerts
Maybe people starting to part their stock piles.
welndmn
A lot of people I know just go aftermarket housings.
They have really come down in price and once you factor in a rebuild and add gears and a locker, the aftermarket housings really start to show their value.
tatersalad
If memory serves me, I think I paid Tom's 1000.00 for the one I am running on my rig and that was in the late 90's.
stout22
Athens, AL
Around here the 77s seem to rust out worse than any other year.
