mofoco1
Swapping 79 to 74 knuckles out. Am rebuilding them. No problem taking them off. No problem installing till, almost done. The upper one is stuck flush with the inside of the knuckle. The problem it seems is that there isn't a cup that is small enough to fit properly inside the casting and allow use of the cast cup on the opposite side. Ideally I need a very shallow cup with just enough ID to allow the Ball Joint to move past the knuckle ear and seat all the way. My question is, is there such a shallow cup, anyone experience these before, this is my first time swapping out the Ball Joint's and I really thought the AutoZone rental tool was going to cut it. It did do 99% off the job, so what do I have to do. If there is a part # from a Napa, Kragen, or maybe even AutoZone, that supplements the original kit please chime in. I would love to finish them off today if possible......Mo in Clovis
