1989 Ford Econoline 302 swap
thumper
Bountiful, Utah
I just bought an 1989 Ford Econoline Van with a 302 ci auto tranny engine with efi and a/c. I want to swap it into my beast this winter and have the teralow d20 gear reduction done.
What are the things I need to get off of the van and engine, and what issues am I going to be dealing with from the van configuration to the Bronco?? Come on you experts, let me know!!
CodeeB
Atlanta
If your van has the saginaw p/s pump you can use the brackets if you are going to use a serpentine belt set-up .
trailpsycho
You will probably need a big body lift if you plan to use the EFI off the van...the motor will be fine, but the van/truck intakes are quite tall and will not fit under your hood without making a hole in it and or a body lift.
Do a search for fuel injected engine swaps and visit www.fordfuelinjection.com
Another question, what about your transission, is the van AOD, do you pla to use that, are you keeping whatever you have?
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
You will need an Xtreme body lift to avoid having to cut the hood, and most hood scoops are the wrong size/shape to help.
This Bronco had a medium body lift and you can see what still needed to be cut.
Low rise (car style) intakes that fit under the hood are easy enough to find but the tall truck/van intakes make for better low end grunt.
thumper
thumper
Bountiful, Utah
The engine that I bought does have the Saginaw pump on it which is cool. It does have the AOD tranny which I planned on using also. I have my hood already cut out to fit the DUFF SCOOP, I needed the clearance for the pulley on my YORK on-board air set-up. What else should I have to worry about and will this WORK????? I also want to do the TERALOW D20 gear reduction at the same time--any problems there???
OK, the clearance issue with the hood is still going to be a problem unless you do a mustang style intake. The front of the intake is tall and the hood you describe (if it is what I think it is) won’t clear at the front near the radiator.
The AOD will work, but you have to completely take it apart to install the output shaft for the adaptor, might as well rebuild it if you have it all apart. Tera-Lo will work just fine
Not sure about the York on board air, you will need to do some custom brackets there
SaddleUp
Vancouver, WA
As was already suggested you'll probably want to swap a car intake on it. The intake on my 5.8 F350 motor still sticks up a few inches with a 3" body lift and it is in front of where the scoops or scooped hoods usually go up. With a car intake on your 5.0 it shouldn't be an issue though. Looks like you will also need an adapter kit for the AOD to the D20 T-Case. Beyond this it is mostly little details that you'll need to work through such as where to put the ECM and the wiring for it. Pretty much all of the details are covered in many various efi engine swap articles that are found with any internet search for "Early Bronco EFI swap".
Bart
Buffalo Gap, Texas
Look at the van's shift indicator. Notice there's no second gear positon. Controling second gear off road is next to impossible unless you buy a specially modified valve body and torque converter from a company in Canada. I just ordered mine to the tune of almost $700. And that's on top of the grand I paid to have the trans custom built with Super coupe gear ratios.
What's the deal with the d20 low range. I've heard they have a 4to1 rebuild kit.
