1989 TTB ford D-44 axle
fatboy
Glad to be here.
New Hampshire
Rebuilding my 76 D-44 and I basically need spindles, hubs, rotors and lock outs. Have a chance to pick up a TTB D-44 with newer hubs on it and decent brakes. Can I use the parts off of this for the 76? Will they swap right over?
harder93
when i was looking at doing the same kind of thing what i found out is that the ttb and solid axles are completely different in just about everyway even though they are both a d44. i do not believe that the spindles will work but i think the brakes will not 100% on that and i dont think hubs will either
Skiddy
i think the lockouts are all your going to be able to use
or you could just buy it high and sell it low;D
SpareParts
If you are running the 78-79' Ford or the Chevy disk brake set-up, the rotors, hubs, lockouts, lock nuts and washer will all work for sure. The outer stub shafts work if I remember correctly but I'm not 100% for sure.
In other words, get a set of Chevy spindles along with the brake backing plates and you will have the Chevy conversion.
broncnaz
as was said hubs and rotors and lock out will work. nothing else. Well maybe the calipers but for what its worth only the hubs and rotors are worth grabbing.
