av8rds
MAhole!
I bought this from a buddy because its gorgeous but in retrospect I'd rather spend the money on my house. So I'd also be interested in a Kubota/Deere 25-35hp TLB or tracked skidsteer.
1993 Cobra with 50k original miles, exceptionally clean inside and out, nicer than my truck that's never been out in the snow.posting with more details
347 Stroker built by RNH Performance
Dart Iron Eagle block, 4.125” bore
Eagle 4340 crank with 4340 H-beam rods
Diamond pistons
AFR 225 heads, ported to 234cc intake runners, 58cc chambers
Manly Nex-tek valve springs with titanium retainers
Comp Cams Pro Magnum rockers, 1.6 ratio
Custom solid roller cam @.050 is .577/.577 218/218 at 114
Canton 7qt pan, high flow pickup, RNH breather system
Holley 75mm throttle body
Edelbrock Super Victor intake with matching efi fuel rails
60lb injectors
FAST XFI 2.0
HP Performance turbo kit with 76mm ball bearing turbo
Air to air intercooler
Tial 44mm wastgate
Billet blow-off valve
1 ¾ headers with 3 inch downpipe
Pypes Race Pro exhaust
Aeromotive 1000 fuel pump and filter with A1000 regulator
BBRC aluminum fuel cell
MSD 6A box with MSD wires, FAST distributor
Custom dual pass radiator
Build AOD with Lentech Strip Terminator full manual valve body with electric OD
PTC custom converter
Ford Racing aluminum driveshaft
8.8 rear that has been narrowed with 9” ends
Eaton carrier with carbon clutches, 3.31 gears
Strange 31 spline axles with 5/8 studs
UPR Pro series adj upper and lowers, custom adj. mounts on rear end
Wild Rides battle box supports
Subframe connectors
Viking Crusader with AK (no prep) valving double adj shocks
Team Z Motorsports PAC springs
UPR narrowed front A-arms
Viking Crusader with AK (no prep) valving double adj coil-overs
UPR aluminum caster/chamber plates
Weld V series 17” fronts with MT tires
Weld Vitesse single beadlocks with MT tires, 275/60/15
Factory interior with Autometer gauges
Hurst shifter with custom shift plate
