    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
SOLD 1994 351W Roller Block - Rebuilt-$1400
Status
Not open for further replies.
Tonka7777
Greenville
1994 Ford 351W out of a Bronco. No longer have a need for it. It had 60K miles on it before the rebuild. It was built by Scott Noe of Noe's Performance in Morristown, TN about 5 years ago. Totally stock rebuild (stock bore & stroke), Bores were honed & crank polished, new cam bearings & freeze plugs, new valve job was performed and new valve seals on the heads. We used Sealed Power main/rod bearings,stock rods/pistons, Sealed power piston rings, Edelbrock Performer timing gears/chain, Melling oil pump, Gates water pump. Stock '94 truck camshaft was reused. It has a brand new NOS Ford Oil Pan that has been KBS coated silver, new timing cover, Chrome valve covers, new Motorcraft plugs. The original distributor and oil dipstick. Painted Old Ford Blue with Eastwood Ceramic engine paint. The original intake is still on it. Been sitting on a stand, wrapped up, crank turned every 3 months. Comes with the upper intake, original Ford valve covers, wiring harness, and air intake parts. Stand is included.
svorsp
Sorry, could not read price because of Tapatalk, found it online
Tonka7777
Tonka7777
Greenville
Yes, it will fit a 1970. If it was originally set up for a straight 6, then you would need to replace the motor mounts on the frame. If it was a 289 or 302, you should have no problem.
fordguy
do you remember or know the bore size after hone?
Tonka7777
Tonka7777
Greenville
Bore is still 4.000. The engine was no where near needing a rebuild, but was done anyway because I had wanted to put a "brand new" Bronco on the road when it was done.
Tonka7777
Tonka7777
Greenville
Yes, I can ship it if you want to arrange it. I can drop it off at the freight facility.
If you prefer, I will be in Memphis, TN this coming Friday, Saturday, and Sunday and can bring it with me if you to want pick it up there. I believe Memphis is 3 hours from Vicksburg. Would need to know by Wednesday. My # is 864 991 5353.
Status
