- Apr 28, 2017
- 478
This is not really Bronco related, but I am hoping since it is a 5.0 it could be slightly related so I can get some help from the engine guys. I am really in a bind on this.
My daughters 1996 Explorer developed a squealing noise at idle. I though it might be a pulley but it wasn't. It turned out to be the cam synchro. I guess this is a common problem for the busing to go bad and then squeal. I thought no big deal I have worked on a few of these and I have an Explorer 5.0 motor in my 1976 (Look, it is Bronco related now!) so I thought i would just swap it out. Now here comes the problem. It is stuck... and I mean STUCK!!
The housing rotated freely, but I couldn't get the thing to come out. I put the alignment tool on it thinking I could grab a hold of it and get it to rotate up and out like a distributor, but it bent the little half round piece inside the synchronizer. I pulled and pushed and tapped but I couldn't get it out. After about three hours of frustration, I drilled the top of the shaft off and pulled the housing off thinking I could get a hold of it with vice grips or something to pull it out...wrong.
After screwing with it for another couple hours, I thought to myself, the only way I am going to get his thing free is to pull the timing cover and see what is going on. So that is what I did.
I pulled the cover and was able to get the cam out maybe a 1/16 of an inch or a little more. I can see that the gear on the synchro is not binding on the cam. It is just stuck, on what I am thinking is maybe the oil pump shaft. I got a long punch and tried to hit it up from underneath the collar on the shaft but that didn't work.
So don't laugh at this because I really was getting pissed at the stupid thing. I finally hooked my cherry picker with vice grips to it and gave it a tug while I taped a rotated and that wouldn't even budge it...
The car has about 130k on it and by no means is a piece of junk, but I am not interested in putting an engine or anything in it. I would rather just part it out if it came down to it.. its a $1500-$2000 car and I just don't have the time.
Any ideas or suggestions would be appreciated. This isn't my first rodeo, and I really feel like I have given it everything I can think of.
I am just hoping maybe someone else has a brilliant idea.
