Hey kcc, I can help you with any and all questions and concerns you have about James Duff Products.
Our basic 2.5" suspension shown in the link below is $999.95 the largest cost is your new coil and leaf springs. You do pay a little more for them but its for a great cause. Our springs use all american steel and are built right here in the good ole US of A. We try to make or buy everything here state side because we believe in this country and the people in it that make it so great. Plus I may be old fashioned but I really like putting as many usa made parts on an American Classic like the Ford Bronco.
http://www.dufftuff.com/2_5_2_1_2_suspension_lift_kit_early_ford_bronco_p/5000a--.htm
A few other components about this lift I'd like to point out is you'll notice we don't supply a drop trac bar bracket. Instead we supply an adjustable trac bar. You'll notice that some lifts come with certain components and then you need to add/buy additional ones to make small corrections. This lift is all inclusive with no added or extra costs. Typically when you buy a drop trac bar bracket you will also need a drop pitman arm to correct your steering geometry(which in some lifts is an added cost). Drop trac bar brackets need to be welded on then painted and you will need some help removing your original pitman arm if its been on for 40-50 years. (Usually a puller you would rent or buy from a parts/tool store). With a 2.5" lift we found that just adding an adjustable trac bar side stepped those two steps, solved two issues and is a whole lot less labor intensive. This also makes the lift 100% bolt on right in your garage or driveway.
I really like the 2.5" lift for your Bronco. It sounds like a good fit for it and you. You will also enjoy the added benefits of not needing longer drive shafts, not battling caster/road handling issues, retaining the stock brake lines and e brake cables. With that being said you may want to inspect the rubber brake lines that run from your axle to your frame and see what condition they are in. this would be a good time to replace those if they look weather checked and cracking.
Feel free to message me here or email me with any of your questions.
monstermike@jamesduff.com
good luck which ever way you go!
Michael
